Perform this procedure to disable the virtual service.
    enable
    configure terminal
  2. Disable the virtual service:
    no virtual-service WORD<1-128> enable
Disable the virtual service.
Switch:1>enable
Switch:1#configure terminal
Enter configuration commands, one per line.  End with CNTL/Z.
Switch:1(config)#no virtual-service tpvm enable
